ESD system - override signals
In an Emergency Shutdown (ESD) system, an override signal is used to temporarily alter or prevent the normal response of a specified ESD function under controlled conditions.
This is a safety-critical operation and must never be treated as an ordinary control command.
:small_blue_diamond: What Is an Override Signal?
An override signal is a controlled signal or command that causes a specified ESD logic function to behave differently from its normal configuration.
For example:
High Pressure Switch β†’ ESD Logic β†’ Shutdown Valve
Normally:
:police_car_light: High pressure detected
:down_arrow:
:brain: ESD logic
:down_arrow:
:locked: Shutdown valve closes
If an authorized override is active, the specified trip action may temporarily be prevented or modified, depending on the ESD design.
:factory: Why Are Override Signals Used?
Typical reasons include:
:wrench: Instrument maintenance
:test_tube: Functional testing
:construction: Commissioning
:magnifying_glass_tilted_left: Troubleshooting
:gear: Temporary operating conditions
For example, a pressure transmitter may need to be removed for maintenance while the process remains operational.
An approved override arrangement may temporarily prevent that particular signal from causing an unwanted shutdown.
:counterclockwise_arrows_button: Simple Example
Normal ESD operation:
PT High-High β†’ ESD Trip β†’ SDV Close
With an authorized override:
PT High-High β†’ Override Active β†’ Specified Trip Action Prevented
:warning: The exact logic depends on the approved Cause & Effect and SIS/ESD philosophy.
:police_car_light: Why Are Override Signals Dangerous?
When an override is active:
:cross_mark: A protection function may be unavailable
:cross_mark: The process risk may increase
:cross_mark: A genuine hazardous condition may not produce the expected shutdown
For example:
:police_car_light: Actual high pressure occurs
:down_arrow:
:satellite_antenna: Transmitter sends trip signal
:down_arrow:
:locked_with_key: Override remains active
:down_arrow:
:cross_mark: Intended ESD action is prevented
This is why override management is extremely important.
:shield: Good Override Practices
An ESD override should normally be:
:clipboard: Authorized
:warning: Risk assessed
:bell: Clearly indicated
:busts_in_silhouette: Communicated to operations
:memo: Recorded/logged
:stopwatch: Controlled for duration
:counterclockwise_arrows_button: Removed after the activity
:white_check_mark: Verified after restoration
Where the system supports it, additional controls such as time limits, access restrictions, or automatic removal can reduce the risk of a forgotten override.
:vs_button: Override vs Force vs Bypass
These terms can be confusing because different ESD/SIS platforms use different terminology.
Override:
:locked_with_key: Temporarily modifies or prevents a specified function/action.
Force:
:test_tube: Forces a selected input/output/state to a defined value.
Bypass:
:counterclockwise_arrows_button: Temporarily prevents a specified safety function from performing its normal action.
:backhand_index_pointing_right: Always refer to the specific ESD vendor documentation and project philosophy to determine exactly what each function does.
:bullseye: Interview Question
Why are override signals used in an ESD system?
:backhand_index_pointing_right: Override signals are used to temporarily modify or inhibit a specified ESD action for approved activities such as maintenance, testing, commissioning, or defined operating conditions, while applying appropriate controls to manage the resulting reduction in protection.
:light_bulb: Remember
:police_car_light: An ESD override is not a normal operating control. It is a temporary impairment of a safety function.
Use only when necessary β†’ Control the risk β†’ Monitor it β†’ Remove it β†’ Verify the ESD is restored. :locked::white_check_mark:
#ESD #ESDSystem #Override #SIS #SafetyInstrumentedSystem #FunctionalSafety #ProcessSafety #SafetyPLC #IEC61511 #Instrumentation dcs #IndustrialAutomation #ControlSystems #OilAndGas #InstrumentationEngineer :police_car_light::gear::factory:
