ESD vs PSD
:police_car_light::gear: ESD vs PSD: What Is the Difference Between Emergency Shutdown and Process Shutdown? :factory:
These two terms are commonly used in oil & gas and process plants, but they are not necessarily identical. The exact terminology and hierarchy depend on the plant’s shutdown philosophy.
:red_circle: ESD — Emergency Shutdown
ESD (Emergency Shutdown) is a safety-related shutdown function intended to bring the process or affected plant section to a defined safe state when a hazardous or emergency condition occurs.
Typical ESD initiators may include:
:fire: Fire detection
:dashing_away: Gas detection
:police_car_light: High-high pressure
:thermometer: High-high temperature
:stop_sign: Emergency pushbutton
:warning: Major equipment failure
A typical sequence could be:
Hazardous condition → ESD Logic → Shutdown valves close → Equipment trips → Hazardous energy isolated
The objective is:
:shield: Protect people, equipment, and the environment by moving the process toward a safe state.
:yellow_circle: PSD — Process Shutdown
PSD (Process Shutdown) generally refers to a shutdown function intended to stop a process or equipment because of an abnormal process condition or equipment protection requirement, without necessarily representing an emergency condition.
Examples:
:gear: Pump failure
:chart_decreasing: Low suction pressure
:thermometer: High process temperature
:droplet: Low tank level
:wrench: Equipment malfunction
For example:
Low lube-oil pressure → PSD → Compressor shutdown
The purpose is often to protect equipment and prevent process damage.
:vs_button: ESD vs PSD
ESD :red_circle: PSD :yellow_circle:
Emergency/safety shutdown Process/equipment shutdown
Typically associated with hazardous/emergency conditions Typically associated with abnormal process/equipment conditions
Intended to achieve a defined safe state Often intended to protect equipment/process
May isolate major process sections May shut down individual equipment or process units
Can be part of SIS May be implemented in BPCS/DCS or SIS depending on requirements
Higher safety significance when implemented as a SIF Safety significance depends on the specific function
:factory: Simple Example
Imagine a gas compressor.
Case 1 — PSD
Lubricating oil pressure becomes dangerously low:
:chart_decreasing: Low lube oil pressure
:down_arrow:
:stop_sign: Compressor shutdown
:down_arrow:
:wrench: Equipment protected
This could be a PSD function.
Case 2 — ESD
A confirmed major gas release or fire occurs:
:fire: Fire/Gas detection
:down_arrow:
:police_car_light: ESD initiated
:down_arrow:
:locked: Isolation valves close
:down_arrow:
:stop_sign: Equipment/process shutdown
:down_arrow:
:shield: Plant moves toward a safe state
:warning: Important: ESD and PSD Are Not Universally Defined
This is especially important in interviews.
Different companies may use terms such as:
PSD → ESD → F&G → Unit Shutdown → Plant Shutdown
with different levels and priorities.
Some facilities may implement PSD functions within the SIS, while others may use the BPCS/DCS for certain process shutdowns.
Therefore, don’t say:
:cross_mark: “PSD is always DCS.”
or:
:cross_mark: “ESD is always a separate PLC.”
Instead:
The implementation and terminology depend on the plant shutdown philosophy and safety requirements.
:bullseye: Interview Question
What is the difference between ESD and PSD?
:backhand_index_pointing_right: PSD generally shuts down equipment or a process because of abnormal operating or equipment-protection conditions, whereas ESD is intended to respond to emergency or hazardous conditions and bring the affected process to a defined safe state.
:light_bulb: Easy way to remember:
:yellow_circle: PSD → Protect the Process/Equipment
:red_circle: ESD → Respond to an Emergency and achieve a Safe State
:police_car_light: But always verify the specific plant’s shutdown philosophy before assigning a particular function to ESD or PSD.
#ESD #PSD #EmergencyShutdown #ProcessShutdown #SIS #ESDSystem #ProcessSafety #FunctionalSafety #IEC61511 #SafetyInstrumentedSystem dcs #PLC #Instrumentation #OilAndGas #IndustrialAutomation #ControlSystems :police_car_light::gear::factory:
