| ACRONYMS | FULL MEANING |
| Ack | Acknowledge |
| AE | Application Entity |
| AI | Analog Input |
| AO | Analog Output |
| AP | Application Program |
| AP | Application Process |
| APDU | Application Layer Protocol Data Unit |
| AR | Application Relationship |
| AREP | Application Relationship End Point |
| ARP | Ethernet Address Resolution Protocol |
| ARPM | Application Relationship Protocol Machine |
| ASN.1 | Abstract Syntax Notation 1 |
| BOOTP | Bootstrap Protocol |
| CAP | Control Application Process |
| Cas | Cascade |
| CD | Compel Data |
| CFF | Capability File Format |
| CFF | Common File Format |
| CNF | Confirmation |
| CNLS | Connectionless |
| COM | Communication |
| Config | Configuration |
| CONN | Connection-Oriented |
| CSMA/CD | Carrier Sense Multiple Access / Collision Detect |
| DAP | Device Application Process |
| DCS | Distributed Control System |
| DD | Device Description |
| DDL | Device Description Language |
| DevId | Device Identifier |
| DHCP | Dynamic Host Configuratin Protocol |
| DI | Discrete Input |
| DL | Data Link |
| DLCEP | Data Link Connection End Point |
| DLL | Data Link Layer |
| Dlme | Data Link Layer Management Entitity |
| DLPDU | Data Link Protocol Data Unit |
| DLSAP | Data Link Service Access Point |
| DMA | Direct Memory Access |
| DNS | Do Not Select |
| DO | Discrete Output |
| DPS | Draft Preliminary Specification |
| DS | Data Structure |
| DTC | Data Transfer Confirmed |
| DTU | Data Transfer Unconfirmed |
| DUT | Device Under Test |
| DV | Dynamic List of Variable List |
| EFD | (High Speed) Ethernet Field Device |
| EGP | Exterior Gateway Protocol |
| EP | Ethernet Presence |
| EPI | Ethernet Presence Interface |
| ERR | Error |
| EU | Engineering Unit |
| FAS | Fieldbus Access Sublayer |
| FB | Function Block |
| FBAP | Function Block Application Process |
| FDA | Field Device Access |
| FDA | Field Device Application (Agent) |
| FDA | Field Device Access Agent |
| FDL | Fieldbus Data Link Layer |
| FF | Fieldbus Foundation |
| FFB | Flexible Function Block |
| FMS | Fieldbus Message Specification |
| FMS | Fieldbus Messaging System |
| FS | Final Specification |
| FSA | Fail-Safe Active |
| FSA | Fault Statefail -Safe Active |
| FSPM | FDA Service Protocol Machine |
| Gen | Generic |
| H1 | Hunk 1 |
| HFD | HSE Field Device |
| HL | Link Designator of a four-octet LONG DL-address |
| HL.N.S | Four-octet LONG DL-address |
| HLD | Higher Level Device |
| HMA | HSE Management Agent |
| HSE | High Speed Ehternet |
| I/O | Input / Output |
| IA | Initialization Acknowledge |
| IANA | Internet Assigned Numbers Authority |
| ICMP | Internet Control Message Protocol |
| ICS | Implementation Conformance Statement |
| ID | Identifier |
| Id | Identifier |
| IEEE | Institute of Electrical and Electronics Engineers |
| IETF | Internet Engineering Task Force |
| IGMP | Internet Group Management Protocol |
| IMan | Initialization Manual |
| IND | Indication |
| INFO | Informational |
| IP | Internet Protocol |
| IPv4 | Internet Protocol, Version 4 |
| IPv6 | Internet Protocol, Version 6 |
| IR | Initialization Request |
| IT | Information Technology |
| IUT | Implementation Under Test |
| LAN | Local Area Network |
| LAS | Link Active Scheduler |
| LD | Linking Device |
| LDM | Last Delivered Message |
| LLC | Logical Link Control |
| LME | Layer Management Entity |
| LO | Local Override |
| LOP | Local Operator Panel |
| LRE | LAN Redundancy Entity |
| LS | Link Schedule |
| LSB | Least Significant Bit |
| LUV | Last Usable Value |
| MAC | Medium Access Layer |
| MAC | Medium/Media Access Control |
| MAI | Multiple Analog Input |
| MAO | Multiple Analog Output |
| MAU | Medium Attachment Unit |
| Max. | Maximum |
| Mb/s | Megabits per second |
| MDI | Multiple Digital Input |
| MDI | Multiple Discrete Input |
| MDO | Multiple Digital Output |
| MDO | Multiple Discrete Output |
| MDS | Medium Dependent Sublayer |
| Mfr. | Manufacturer |
| MIB | Management Information Base |
| MIB-II | Management Information Base II |
| MSB | Most Significant Bit |
| Msg | Message |
| MVC | Multi-Variable Container object |
| N.S. | Sub-link Selector of a four-octet LONG DL-address |
| NI | Not Invited |
| NM | Network Management |
| NMA | Network Management Agent |
| NMIB | Network Management Information Base |
| NST | Network Status Table |
| NTP | Network Time Protocol |
| OD | Object Description |
| OD | Object Dictionary |
| OSI | Open System Interconnection |
| PD | Physical Device |
| PD Tag | Physical Device Tag |
| PDU | Protocol Data Unit |
| PhPDU | Physical Layer Protocol Data Unit |
| PHY | Physical Layer |
| PICS | Protocol Implementation Conformance Statement |
| PID | Proportional Integral Derivative (control algorithm) |
| PLC | Programmable Logic Controller |
| PN | Probe Node PDU |
| PR | Probe Response PDU |
| PROP | Proposed |
| PS | Preliminary Specification |
| PT | Pass Token |
| RCas | Remote Cascade |
| RED | Redundant |
| Ref | Reference |
| REQ | Request |
| RFC | Request For Comments |
| RFU | Reserved for Future Use |
| ROut | Remote Output |
| RSE | Remote Single Layer Embedded |
| RSP | Response |
| RT | Return Token |
| SM | System Management |
| SMI | Structure and Identification of Management Information |
| SMIB | System Management Information Base |
| SMK | System Management Kernel |
| SMKP | System Management Kernel Protocol |
| SMKPM | System Management Kernel Protocol Machine |
| SMPM | Socket Mapping Protocol Machine |
| SNMP | System Network Management Protocol |
| SNTP | Simple Network Time Protocol |
| STD | Standard |
| SUT | System Under Test |
| TCP | Transmission Control Protocol |
| TCP/IP | Transmission Control Protocol / Internet Protocol |
| TD | Time Distribution |
| TOS | Type Of Service (IP definition) |
| TTCN | Tree & Tabular Combined Notation |
| TTL | Time To Live (IP definition) |
| UDP | User Datagram Protocol |
| VCR | Virtual Communication Relationship |
| VCRL | Virtual Communication Relationship List |
| VFD | Virtual Field Device |
| FF Acronyms in Book | |
| A | Arithmetic |
| AA | Analog Alarm |
| AHI | Analog Human Interface |
| AI | Analog Input |
| Auto | Automatic |
| BG | Bias/Gain Station |
| C | Calculate |
| CAO | Complex Analog Output |
| Cas | Cascade |
| CDO | Complex Discrete Output |
| CS | Control Selector |
| DA | Digital Alarm |
| DC | Device Control |
| DHI | Digital Human Interface |
| DL | Data Link |
| DT | Deadtime |
| FISCO | Fieldbus Instrinsically Safe Concept |
| H1 | Fieldbus Low Speed Data Network |
| HSE | High Speed Ethernet |
| Iman | Initialization Manual |
| IS | Input Selector |
| IT | Integrator (Totalizer) |
| LAS | Link Active Schedule |
| LL | Lead Lag Controller |
| LM | Link Master |
| LS | Link Scheduling |
| MAC | Management Access Control |
| MAI | Multiple Analog Input Block |
| Man | Manual |
| MAO | Multiple Analog Output Block |
| MDI | Multiple Discrete Input Block |
| MDO | Multiple Discrete Output Block |
| ML | Manual Loader |
| OOS | Out Of Service |
| OS | Output Splitter Block |
| PD | Proportional Derivative |
| PD | Process Data |
| PI | Pulse Input |
| PID | Proportional Integral Derivative |
| RA | Ratio |
| RB | Resource Block |
| RX | Receive/Receiver |
| SC | Signal Characterizer |
| SOPID | Step Output PID |
| SRG | Set Point Ramp Generator |
| SS | Signal Splitter |
| STP | Shielded Twisted Pair(s) |
| T | Timer |
| TD | Transducer Block |
| TX | Transmit/ Transmitter |
| UTP | Unshielded Twisted Pair(s) |
| VCR | Virtual Communication Resource |
| XD | Transducer |
| non-FF Acronyms in Book | |
| AWG | American Wire Gauge |
| DCS | Digital Control System |
| HMI | Human Machine Interface |
| I/O | Input/Output |
| IEC | International Electrotechnical Commission |
| IS | Intrinsically Safe |
| ISA | Instrumentation, Systems, & Automation Society |
| ISO | International Standards Organization |
| mA | milliamps |
| NIS | Non-Intrinsically Safe |
| OLE | Object Linking and Embedded |
| OPC | OLE for Process Control |
| PTB | Physikalisch Technische Bundesanstalt |
| SCADA | Supervisory Control And Data Acquisition |
| SP | Set Point |
| VDC | Volts Direct Current |
| XML | eXtensible Mark-up Languange |
