A valve that does not have integral line flanges. This type of valve is sometimes referred to as a Wafer Style valve.
The valve is installed by bolting it between the companion flanges with a set of bolts or studs called line bolting.
Care should be taken that strain hardened bolts and nuts are used in lieu of all thread, which can stretch when subjected to temperature cycling.
