Flow nozzle:
As compared to the orifice plate, flow nozzle is better option as no possibility of solid particles or bubbles of gas sticking in the flow restriction. The flow across nozzle is as shown in the figure below.
The measurement accuracy of the flow nozzle is very high as no harm of getting warned out. But the cost is comparatively higher as fabrication of the flow nozzle is difficult. Also permanent pressure losses are also high similar to the orifice plate. The flow nozzles are typically used for the steam flow measurement.
