Functional Safety in SIS System
:shield: What is Functional Safety? — Explained for Engineers
In automation, safety is not just hardware…
It’s about how systems respond when things go wrong :backhand_index_pointing_down:
:right_arrow: Ensuring a system operates safely under normal and abnormal conditions
:right_arrow: Focus on automatic protection when failures occur
:right_arrow: Defined by standards like IEC 61508 / IEC 61511
:brain: Simple idea
:backhand_index_pointing_right: If something fails → System should go to a safe state
Examples:
:fire: High pressure → Shutdown
:fire: Gas leak → Trip system
:rocket: Why it is important
:high_voltage: Prevents accidents & hazards
:high_voltage: Protects people, equipment & environment
:high_voltage: Reduces risk in critical processes
:high_voltage: Ensures compliance with safety standards
:backhand_index_pointing_right::backhand_index_pointing_right: WATCH VIDEO:
:factory: Where it is used
:oil_drum: Oil & Gas plants
:alembic: Chemical industries
:high_voltage: Power plants
:factory: Process industries
:wrench: Key elements
:small_blue_diamond: Sensors → Detect abnormal condition
:small_blue_diamond: Logic Solver (Safety PLC) → Makes decision
:small_blue_diamond: Final Element (Valve/Trip) → Takes action
:backhand_index_pointing_right: Together they form a Safety Instrumented System (SIS)
:bullseye: Key concept
:right_arrow: Not about avoiding failure
:right_arrow: It’s about handling failure safely
:warning: Important
:cross_mark: Safety ≠ Just alarms
:white_check_mark: Safety = Automatic protective action
:backhand_index_pointing_right: Control System = Runs the process
:backhand_index_pointing_right: Functional Safety = Protects the process when control fails
#FunctionalSafety #ProcessSafety #SIS Automation #Instrumentation #ControlSystems #Engineering #IndustrialAutomation #IEC61511 #SafetyEngineering :rocket:
