High Integrity Pressure Protection System (HIPPS)
:police_car_light::shield: HIPPS: The Safety System That Stops High Pressure Before It Becomes a Disaster! :shield::police_car_light:
Imagine a pipeline or process vessel designed for a maximum pressure of 100 bar.
But upstream equipment can potentially generate:
:fire: 150 bar
Allowing that pressure to reach the downstream equipment could cause:
:collision: Overpressure
:collision: Equipment damage
:collision: Pipeline rupture
:collision: Fire or toxic release
So how can we protect the lower-pressure section?
:backhand_index_pointing_right: HIPPS β€” High Integrity Pressure Protection System
:small_blue_diamond: What is HIPPS?
HIPPS is a high-integrity safety system designed to prevent excessive pressure from reaching downstream equipment by detecting an overpressure condition and rapidly isolating the high-pressure source.
In simple terms:
:police_car_light: Detect high pressure β†’ Trip β†’ Close shutdown valves β†’ Stop overpressure propagation
HIPPS is typically implemented as a Safety Instrumented System (SIS) and is designed according to functional-safety requirements.
:factory: How Does HIPPS Work?
A typical HIPPS arrangement may include:
Pressure Sensors β†’ Safety Logic Solver β†’ Final Elements
For example:
:satellite_antenna: Pressure Transmitters
:down_arrow:
:brain: Safety PLC / Logic Solver
:down_arrow:
:locked: Shutdown Valves
:down_arrow:
:oil_drum: Protected downstream system
If the pressure reaches the defined trip condition:
:police_car_light: High-high pressure detected
:down_arrow:
:brain: HIPPS logic evaluates the condition
:down_arrow:
:locked: Shutdown valves close
:down_arrow:
:no_entry: High-pressure source is isolated
:down_arrow:
:shield: Downstream equipment is protected
:magnifying_glass_tilted_left: Why Multiple Pressure Transmitters?
HIPPS often uses redundant pressure sensors to improve availability and reduce the probability of an unwanted trip.
For example, a system could use:
2oo3 voting
Meaning:
:backhand_index_pointing_right: 2 out of 3 pressure transmitters must indicate the trip condition before the HIPPS initiates shutdown.
This helps balance:
:green_circle: Safety
:green_circle: Availability
:green_circle: Spurious-trip resistance
The actual voting architecture depends on the required safety integrity and system design.
:locked: What Makes HIPPS β€œHigh Integrity”?
HIPPS is not simply:
Pressure transmitter + shutdown valve
It is engineered as a safety function with requirements for:
:white_check_mark: Independence where required
:white_check_mark: Redundancy
:white_check_mark: Diagnostic capability
:white_check_mark: Defined Safety Integrity Level (SIL)
:white_check_mark: Reliable final elements
:white_check_mark: Proof testing
:white_check_mark: Functional safety management
:white_check_mark: Controlled bypass/inhibit arrangements
:white_check_mark: Appropriate failure response
:vs_button: HIPPS vs Conventional Relief Valve
A conventional pressure relief system typically:
Overpressure β†’ Relief valve opens β†’ Pressure relieved
HIPPS works differently:
High pressure detected β†’ Shutdown valves close β†’ High-pressure source isolated
HIPPS can therefore help prevent excessive pressure from reaching the protected section, rather than simply relieving the resulting overpressure.
In some applications, HIPPS may allow downstream equipment to be designed for a lower pressure rating, subject to the applicable design and safety requirements.
:warning: Important Point
HIPPS does not simply replace all pressure-relief protection by default.
Whether relief devices remain necessary depends on the process design, credible overpressure scenarios, applicable codes/standards, and the overall protection philosophy.
HIPPS is normally considered as part of a broader Layer of Protection strategy.
:bullseye: Interview Question
What is the purpose of HIPPS?
:backhand_index_pointing_right: HIPPS protects downstream equipment from excessive pressure by detecting a dangerous pressure condition and automatically isolating the high-pressure source through a high-integrity safety function.
:light_bulb: Remember It This Way
HIPPS = Detect β†’ Decide β†’ Isolate β†’ Protect :police_car_light::brain::locked::shield:
And the most important idea:
:fire: HIPPS doesn’t try to control normal process pressureβ€”it acts as an independent high-integrity protection layer when pressure becomes dangerously high.
#HIPPS #HighIntegrityPressureProtectionSystem #SIS #ESD #FunctionalSafety #SIL #IEC61511 #ProcessSafety #PressureProtection #Instrumentation #SafetyPLC #OilAndGas #ProcessControl #IndustrialAutomation #InstrumentationEngineer :police_car_light::factory::gear:
