How does proportional controller generate its output?
Question:
How does a proportional controller generate its output?
Options:
A) From error rate
B) From error sum
C) From error value
D) From SP only
:white_check_mark: Correct Answer: C) From error value
A proportional controller generates its output directly from the current error value.
Where:
  • ( Kp ) = proportional gain
  • ( e(t) = SP - PV )
This means:
  • Larger error → Larger output
  • Smaller error → Smaller output
  • Zero error → Zero proportional contribution
Proportional action reacts instantly to present deviation.
:repeat_button: What It Does NOT Use
  • It does not use the rate of change (that is derivative).
  • It does not use the accumulated error (that is integral).
  • It does not depend on SP alone.
A) From error rate → That describes derivative action.
B) From error sum → That describes integral action.
D) From SP only → Output depends on the difference between SP and PV, not SP alone.
