How is error calculated in a PID controller?
Question:
Options:
A) PV − MV
B) SP + PV
C) SP − PV
D) Output − PV
:white_check_mark: Correct Answer: C) SP − PV
In a standard PID controller, error is calculated as:
Error = SP - PV
Where:
  • SP (Setpoint) = Desired value
  • PV (Process Variable) = Measured value
This error represents the deviation between where the process is and where it should be.
:repeat_button: What the Sign Means
  • If PV < SP → Error is positive → Controller increases output (reverse acting case)
  • If PV > SP → Error is negative → Controller reduces output
The sign determines the direction of correction.
A) PV − MV → MV (manipulated variable) is controller output, not part of error formula.
B) SP + PV → Error is a difference, not a sum.
D) Output − PV → Controller output is not used to calculate error.
:fire: Key Point for Interviews
Error calculation is the foundation of PID control.
All three terms (P, I, D) act on this error signal.
