How will flow rate indication be affected if the equalizing valve for the associated differential pressure detector is fully opened ___
How will flow rate indication be affected if the equalizing valve for the associated differential pressure detector is fully opened?
A. Increase temporarily, and then return to initial value.
B. Decrease temporarily, and then return to initial value.
C. Increase to the maximum value.
D. Decrease to the minimum value.
Answer:D
