If a control switch is drawn with one end of the moveable linkage, or the bar of the switch is hinged to one of the ___
If a control switch is drawn with one end of the moveable linkage, or the bar of the switch is hinged to one of the two wire terminals and the other end of the linkage is fitted with a contact pad, (which makes contact with a single stationary contact pad) a __________ break configuration is created.
If the line and load wire terminals of the switch assembly are connected one each to stationary contact pads within the switch, and the movable bar or actuator within the switch is fitted with two contacts, which, when assembled, align with the two stationary pads, a __________ break configuration is created.
A) single; double
B) double; double
C) single; single
D) double; single
Answer:A
