If a twt used as an oscillator fails, which of the following indications should ___
If a twt used as an oscillator fails, which of the following indications should you observe?
A. The twt will become noisy
B. Equipment line fuses will blow
C. The twt will have reduced output power
D. The twt will fail to break into oscillation when all other conditions are normal
