If one of the 3-phases of supply to an induction motor fails may be due to any reason when the motor is running normally. the motor will
A. continue running at the same speed if it was running on light load.
B. continue running but will draw more current if it was operating at rated load.
C. stop and carry heavy current causing permanent damage to the windings if it was operating overloaded.
D. all of the above.
