If RTD resistance increases, what happens to temperature?
A. Decreases
B. Increases
C. No change
D. Becomes zero
Correct Answer: B
Explanation:
An RTD (Resistance Temperature Detector) operates on the principle that the electrical resistance of the sensing element increases as temperature increases.
For a Pt100 RTD, the relationship can be approximated by:
Where:
  • RT = Resistance at temperature T
  • R₀ = Resistance at 0°C
  • α = Temperature coefficient
  • T = Temperature
From this formula, as the temperature (T) increases, the resistance (RT) also increases.
For example:
  • 0°C → 100 Ω
  • 50°C → 119.4 Ω
  • 100°C → 138.5 Ω
  • 200°C → 175.9 Ω
Since RTD resistance rises with temperature, an increase in resistance indicates that the temperature has increased.
Therefore, Option B (Increases) is the correct answer.
Because the RTD (Resistance Temperature Detector) is a positive temperature coefficient sensor, its resistance increases as the temperature rises.
