If the orifice in a differential pressure (D/P) flow sensor erodes such that the orifice opening becomes larger, indicated flow rate will ___ due to a ___ D/P across the orifice
If the orifice in a differential pressure (D/P) flow sensor erodes such that the orifice opening becomes larger, indicated flow rate will __________ due to a __________ D/P across the orifice.
(Assume actual flow rate remains the same.)
A. increase; larger
B. increase; smaller
C. decrease; larger
D. decrease; smaller
Answer:D
