If the pressure in a closed vessel is greater than the atmospheric pressure (the outside air), then a __________ switch is used to monitor the exact pressure inside the vessel (normally a tank).
If the pressure inside a closed vessel is less than the atmospheric pressure, then a __________ switch is used to monitor the lack of pressure inside the vessel.
A) vacuum; pressure
B) pressure; pressure
C) vacuum; vacuum
D) pressure; vacuum
Answer:D
