If the temperature transmitter fails low (low temperature output signal), the temperature controller will position the temperature control valve in the __________ direction, which causes the actual heat exchanger lube oil outlet temperature to __________.
A. close; increase
B. close; decrease
C. open; increase
D. open; decrease
