In cascade control, secondary loop primarily improves which performance aspect of the main control loop?
A. Accuracy
B. Speed
C. Dead zone error
D. Linearity
Summary
Correct Answer: B. Speed
:brain: Explanation (Cascade Control Concept)
In cascade control, you have two loops:
Primary (Master) Loop โ†’ controls the main variable (e.g., temperature)
Secondary (Slave) Loop โ†’ controls a faster internal variable (e.g., flow)
The secondary loop reacts much faster than the primary loop.
:gear: What actually happens?
When a disturbance enters the process:
It first affects the secondary variable (inner loop)
The secondary controller detects and corrects it immediately
This prevents the disturbance from propagating to the primary loop
:backhand_index_pointing_right: Result: Faster overall response of the system
:repeat_button: Why โ€œSpeedโ€ is the correct answer
The secondary loop reduces the response time Improves how quickly the system reacts to disturbances Minimizes lag before the primary loop even โ€œfeelsโ€ the issue
:backhand_index_pointing_right: In practice:
Without cascade โ†’ slow correction
With cascade โ†’ quick disturbance rejection
:cross_mark: Why other options are wrong
A. Accuracy โ†’ Mainly handled by tuning and steady-state control, not cascade structure
C. Dead zone error โ†’ Related to actuator/sensor non-linearity, not cascade
D. Linearity โ†’ System characteristic, not improved by cascade architecture
:white_check_mark: Final Takeaway
:backhand_index_pointing_right: The main purpose of the secondary loop is to act quickly and stabilize disturbances early.
