In cascade control, where is the PID controller typically used?
Question:
Options:
A) Master only
B) Slave only
C) Both Master & Slave
D) Output stage
:white_check_mark: Correct Answer: C) Both Master & Slave
In a cascade control system, there are two control loops:
  1. Master (Primary) Controller
  2. Slave (Secondary) Controller
Both loops typically use PID control.
:small_blue_diamond: Master Controller
  • Controls the primary process variable
  • Sends its output as the setpoint to the slave controller
:small_blue_diamond: Slave Controller
  • Controls a faster inner variable
  • Directly manipulates the final control element
Using PID in both loops improves:
  • Disturbance rejection
  • Response speed
  • Stability
:repeat_button: Example
Temperature control of a heat exchanger:
  • Master PID → Controls temperature
  • Slave PID → Controls steam flow
The inner (slave) loop reacts faster to disturbances before they affect the primary variable.
A) Master only → Slave loop also requires control logic.
B) Slave only → Master loop still performs primary regulation.
D) Output stage → PID is implemented in controllers, not in output hardware.
