In direct-acting control, output increases when?
Question:
Options:
A) PV rises
B) PV falls
C) Error zero
D) SP drops
:white_check_mark: Correct Answer: A) PV rises
In a direct-acting controller, the controller output increases when the process variable (PV) increases.
Using the standard error formula:
Error = SP - PV
For direct action:
  • If PV rises
  • Controller output also rises
This type of action is used when increasing output must reduce the process variable (for example, cooling applications).
:repeat_button: Example
Cooling control loop:
  • Temperature (PV) rises
  • Controller output increases
  • Cooling valve opens more
  • Temperature decreases
The controller output moves in the same direction as PV — hence direct acting.
B) PV falls → In direct action, output decreases when PV falls.
C) Error zero → Output remains steady at equilibrium.
D) SP drops → Direct/direct action is defined by PV behavior, not SP change.
