In Insulation Resistance Testing, if we are Testing Marked connection of Primary of CT insulation, what will be the set up of Test at CT Connection?
A. Marked Primary energized from Megger, Primary Unmarked and Both secondary connections of CT must be ungrounded.
B. Unmarked Primary energized from Megger, Primary marked and Both secondary connections of CT must be ungrounded.
C. Marked Primary energized from Megger, Primary Unmarked and secondary unmarked connections of CT must be ungrounded.
D. Marked Primary energized from Megger, Primary Unmarked and Both secondary connections of CT must be grounded and connected to Ground connection of Megger.
