Question:
In reverse-acting control, output increases when?
Options:
A) PV rises
B) Error zero
C) PV falls
D) SP rises
Correct Answer: C) PV falls
Detailed Explanation
In a reverse-acting controller, the controller output increases when the process variable (PV) decreases.
Using the standard error equation:
Error = SP - PV
If PV falls below SP:
- Error becomes positive
- Controller increases output
- Final control element acts to raise PV
This is common in temperature and pressure control loops where increasing output increases the process variable.
Example
Temperature control with steam valve:
- PV drops below SP
- Valve opens more
- More steam enters
- Temperature rises
A) PV rises → In reverse action, output decreases when PV rises.
B) Error zero → Output remains steady in ideal steady-state.
D) SP rises → Output may increase, but reverse/direct action is defined by PV behavior.
