In RTD formulas, α represents what?
A. Current coefficient
B. Resistance coefficient
C. Voltage coefficient
D. Power coefficient
Explanation:
In RTD calculations, α (alpha) represents the temperature coefficient of resistance, which indicates how much the RTD resistance changes with temperature.
It appears in the approximate RTD equation:
Where:
  • R = Resistance at temperature T
  • R₀ = Resistance at 0°C
  • α = Temperature coefficient
  • T = Temperature in °C
For a Standard Pt100 RTD
  • α = 0.00385 Ω/Ω/°C
This means the resistance increases by approximately 0.385 Ω per °C near 0°C for a Pt100 RTD.
Why α is Important
:white_check_mark: Defines RTD sensitivity
:white_check_mark: Relates resistance change to temperature change
:white_check_mark: Used in temperature calculations
:white_check_mark: Standardized by IEC 60751
Current coefficient
  • Not represented by α in RTD equations.
  • In RTD terminology, α specifically refers to the temperature coefficient of resistance.
Voltage coefficient
  • Not used in RTD temperature calculations.
Because α defines how resistance changes with temperature, Option D (Temperature coefficient) is the correct answer. :white_check_mark:
