In semiconductor application, which of the following statement is not true?
A. An ohmmeter test across the base-collector terminal of a transistor should show low resistance in one polarity and high resistance in the opposite polarity.
B. A triac is a bidirectional device.
C. An ohmmeter test across a diode shows low resistance in one polarity and high resistance in the opposite polarity.
D. An ohmmeter test across the base-collector of a transistor should show low resistance for both polarities.
