In steady-state condition with correct tuning, the error in a PID loop is ideally?
Question:
Options:
A) Maximum
B) Zero
C) Oscillating
D) Negative
:white_check_mark: Correct Answer: B) Zero
In steady-state operation with proper PID tuning (including integral action), the error:
Error = SP - PV
is ideally zero.
This means:
  • The process variable (PV) equals the setpoint (SP).
  • No continuous deviation exists.
  • The integral term has adjusted the output to remove any steady-state offset.
:repeat_button: Why Integral Action Matters
In proportional-only control, some steady-state error (offset) remains.
With PID (or at least PI) control, integral action accumulates past error until the deviation becomes zero.
A) Maximum → Indicates large deviation; not steady state.
C) Oscillating → Indicates instability or poor tuning.
D) Negative → Error sign depends on PV vs SP, but steady-state ideally means zero error.
