Inhibit vs Bypass
:police_car_light::locked_with_key: INHIBIT vs BYPASS: Are They Really the Same in SIS/ESD? :gear:
These two terms are often used interchangeably in plants, but they can have different meanings depending on the SIS/ESD vendor and project philosophy.
Understanding the distinction is important during commissioning, maintenance, and operation.
:small_blue_diamond: INHIBIT
An inhibit generally means that a particular condition, signal, or action is prevented from participating in a defined logic function.
For example:
High Pressure Signal → ESD Logic → Trip
If the high-pressure input is inhibited:
:police_car_light: High Pressure
:down_arrow:
:locked: Input Inhibited
:down_arrow:
:cross_mark: It does not produce the intended trip through that logic path.
An inhibit may be applied for a specific operating state or maintenance activity, depending on the design.
:small_blue_diamond: BYPASS
A bypass generally means that a specified safety function or part of the safety logic is temporarily prevented from producing its normal action, while the process continues operating.
Example:
Pressure Transmitter → SIS → Shutdown Valve
During approved maintenance:
:wrench: Maintenance required
:down_arrow:
:warning: Safety function temporarily bypassed
:down_arrow:
:hammer_and_wrench: Maintenance performed
:down_arrow:
:white_check_mark: Bypass removed
:down_arrow:
:locked: Safety function restored
:vs_button: Inhibit vs Bypass
Inhibit :locked: Bypass :counterclockwise_arrows_button:
Prevents a signal/condition from participating in logic Temporarily prevents a specified function/action
Often applied to an input or logic condition May apply to a safety function or logic path
Can be part of operating-state logic Often associated with maintenance/testing
Scope depends on system design Scope depends on system design
May be automatically or manually applied Commonly controlled and authorized
:warning: VERY IMPORTANT
There is no universal IEC definition that makes “inhibit” and “bypass” identical or universally different.
Different SIS/ESD manufacturers and project specifications may define these terms differently.
For example, one system may use:
INHIBIT = prevent a trip under a defined process condition
while another may use:
BYPASS = temporarily remove a function from service for maintenance.
Therefore, always check:
:blue_book: SIS Philosophy
:blue_book: Cause & Effect
:blue_book: Logic Diagrams
:blue_book: Vendor Documentation
:blue_book: Operating Procedures
before interpreting the function.
:police_car_light: Why Is This Critical?
Both can potentially reduce the protection provided by an SIS/ESD function.
If a safety function is inhibited or bypassed:
:warning: Protection may be unavailable
:warning: Risk may increase
:warning: Operator awareness is required
:warning: Authorization may be required
:warning: Compensating measures may be necessary
:warning: The function must be restored when the activity is complete
:bullseye: Easy Way to Remember
:locked: INHIBIT → “Don’t let this condition participate in this action.”
:counterclockwise_arrows_button: BYPASS → “Temporarily go around this function.”
But in a real plant:
Don’t rely on the word alone. Check exactly what the SIS logic does when the inhibit or bypass is activated. :police_car_light:
#Inhibit #Bypass #SIS #ESD #SafetyInstrumentedSystem #FunctionalSafety #SIL #IEC61511 #ProcessSafety #SafetyPLC #Instrumentation dcs #IndustrialAutomation #ControlSystems #OilAndGas #InstrumentationEngineer :police_car_light::gear::factory:
