Integral control
:bullseye::gear: INTEGRAL CONTROL: The Control Action That Eliminates Steady-State Error! :counterclockwise_arrows_button:
Imagine a temperature controller with:
:bullseye: Setpoint = 100°C
:thermometer: PV = 95°C
The controller has a 5°C error.
Proportional action responds immediately, but depending on the process and controller, a small error may remain.
:backhand_index_pointing_right: Integral control keeps acting as long as the error persists.
:small_blue_diamond: What is Integral Control?
Integral control is a control action in which the controller output is continuously adjusted according to the accumulated error over time.
In simple words:
:stopwatch: The longer the error exists, the more integral action builds up.
The integral term is based on the accumulated error:
Where:
  • e(t) = Error = SP − PV
  • Kc = Controller gain
  • Ti = Integral time
  • uI = Integral contribution
:factory: Example: Flow Control
Suppose:
:bullseye: SP = 100 m³/h
:chart_decreasing: PV = 90 m³/h
Error = 10 m³/h
The integral controller sees that the error continues to exist and keeps increasing its output.
For example:
Valve output:
40% → 45% → 52% → 60% → 68% …
As the flow approaches the setpoint, the error becomes smaller.
Eventually:
SP ≈ PV
:right_arrow: Steady-state error is eliminated.
:high_voltage: Key Characteristic of Integral Control
The important point is:
Integral action depends on both the magnitude AND duration of the error.
A small error that exists for a long time can produce significant integral action.
For example:
:small_blue_diamond: Large error for short time → Moderate accumulation
:small_blue_diamond: Small error for long time → Significant accumulation
:bullseye: Main Advantage
:white_check_mark: Eliminates steady-state offset
This is why integral action is widely used in:
:thermometer: Temperature control
:droplet: Level control
:ocean: Flow control
:gear: Pressure control
:factory: Process control
:warning: Disadvantages
If integral action is too aggressive, it can cause:
:cross_mark: Overshoot
:cross_mark: Oscillation
:cross_mark: Slow recovery
:cross_mark: Integral windup when the controller output saturates
Therefore, Integral Time (Ti) must be tuned appropriately.
Remember:
:one_o_clock: Small Ti → Stronger integral action
:one_o_clock: Large Ti → Weaker integral action
:vs_button: Proportional vs Integral
Proportional Control:
:backhand_index_pointing_right: Responds to the present error.
Integral Control:
:backhand_index_pointing_right: Responds to the accumulated past error.
A simple way to remember:
P asks: “How big is the error now?”
I asks: “How long has the error been present?” :stopwatch:
:light_bulb: Interview Question
Why is integral control used in a PID controller?
:backhand_index_pointing_right: Integral control is used primarily to eliminate steady-state error (offset) by continuously accumulating the error and adjusting the controller output.
:police_car_light: But remember: Integral action is powerful—if poorly tuned or allowed to wind up during output saturation, it can seriously degrade control performance.
#IntegralControl #PID #PIDControl #ControlSystems #ProcessControl #Instrumentation dcs #PLC Automation #ControlEngineering #IndustrialAutomation #IntegralAction #ProcessControl #InstrumentationEngineer :gear::factory::bullseye:
