Integration of SIS with DCS
:shield: Integration of SIS with DCS — Explained Simply
In modern plants, SIS and DCS work together… but they must remain independent :backhand_index_pointing_down:
:gear: What is DCS?
:right_arrow: Distributed Control System
:right_arrow: Handles normal process control
Controls:
:small_blue_diamond: Temperature
:small_blue_diamond: Pressure
:small_blue_diamond: Flow
:small_blue_diamond: Level
:backhand_index_pointing_right: Goal = Keep process running
:gear: What is SIS?
:right_arrow: Safety Instrumented System
:right_arrow: Protects plant during dangerous conditions
:backhand_index_pointing_right: Goal = Keep process safe
:link: Why integrate SIS with DCS?
Even though they are separate systems, operators still need:
:high_voltage: Alarm monitoring
:high_voltage: Trip indications
:high_voltage: Status monitoring
:high_voltage: Diagnostics & event logs
:brain: How integration happens
Typically through:
:small_blue_diamond: Modbus
:small_blue_diamond: OPC
:small_blue_diamond: Profibus
:small_blue_diamond: Ethernet/IP
:small_blue_diamond: Proprietary safety communication
:backhand_index_pointing_right: SIS shares information with DCS
:warning: Important rule
:cross_mark: DCS should NOT control SIS safety logic
:white_check_mark: SIS must remain independent
:factory: Typical integration data
:satellite_antenna: Trip status
:satellite_antenna: Bypass status
:satellite_antenna: SOE (Sequence of Events)
:satellite_antenna: Fault diagnostics
:satellite_antenna: Shutdown indications
:police_car_light: Real example
:fire: High pressure detected
:backhand_index_pointing_right: DCS tries normal control
:backhand_index_pointing_right: If pressure continues rising → SIS trips process
:backhand_index_pointing_right: DCS displays trip/alarm to operator
:bullseye: Key takeaway
:green_circle: DCS = Process control
:red_circle: SIS = Process protection
Both communicate…
but SIS always remains independent for safety integrity
:backhand_index_pointing_right: DCS runs the plant
:backhand_index_pointing_right: SIS saves the plant
#SIS dcs #ProcessSafety #FunctionalSafety #Instrumentation Automation #ControlSystems #IndustrialAutomation #Engineering #IEC61511 :rocket:
