Intrinsically Safe (IS) vs SIS — One Prevents Ignition, the Other Prevents Accidents
Many engineers confuse IS and SIS because both are related to safety…
But they solve completely different problems ![]()
Electrical protection concept
Limits electrical energy to a safe level
Prevents sparks or heat from igniting hazardous gases
Focus = Explosion Prevention
Typical IS Components
IS barriers
Isolators
IS transmitters
IS field devices
Where IS is used
Oil & Gas facilities
Chemical plants
Fuel storage terminals
Hazardous (Ex) areas
Simple Example
Flammable gas present
IS design ensures the instrument cannot generate enough energy to ignite the gas.
Process safety protection system
Detects dangerous process conditions
Automatically takes action to reduce risk
Focus = Process Protection
Typical SIS Components
Sensors
Safety PLC (Logic Solver)
Shutdown valves
Final control elements
Where SIS is used
Emergency Shutdown Systems (ESD)
High Integrity Pressure Protection Systems (HIPPS)
Simple Example
Reactor pressure becomes dangerously high
SIS trips the process and closes shutdown valves.
Key Differences
IS → Prevents ignition sources
SIS → Prevents hazardous process events
IS → Electrical safety
SIS → Functional safety
IS → Protects hazardous areas
SIS → Protects people, equipment & environment
Simple understanding
IS keeps sparks from causing explosions
SIS keeps process failures from becoming disasters
Important
A plant can have:
IS devices without SIS
SIS without IS devices
Or both together
Because they solve different safety challenges.
#IntrinsicSafety #IS #SIS #FunctionalSafety #ProcessSafety #Instrumentation Automation #SafetyPLC #Engineering #IEC61511
