Layers of Protection Analysis (LOPA)
:shield: LOPA (Layers of Protection Analysis) — Explained Simply
After HAZOP, one key question remains:
:backhand_index_pointing_right: “Is the existing protection enough?”
That’s where LOPA comes in :backhand_index_pointing_down:
:gear: What is LOPA?
:right_arrow: Semi-quantitative risk analysis method
:right_arrow: Evaluates if existing protection layers reduce risk sufficiently
:right_arrow: Helps decide SIL requirements
:brain: Simple idea
:backhand_index_pointing_right: Hazard occurs → What protections are in place?
:backhand_index_pointing_right: Are they enough to reduce risk?
:magnifying_glass_tilted_left: How LOPA works
:one: Identify a hazardous scenario
:two: Define its frequency
:three: Apply independent protection layers (IPLs)
:four: Calculate remaining risk
:brick: Typical Protection Layers (IPLs)
:small_blue_diamond: Basic Process Control System (BPCS)
:small_blue_diamond: Alarms with operator action
:small_blue_diamond: Safety Instrumented System (SIS)
:small_blue_diamond: Relief valves
:small_blue_diamond: Physical barriers
:rocket: Why LOPA is important
:high_voltage: Determines required SIL level
:high_voltage: Avoids overdesign or underdesign
:high_voltage: Provides structured risk decision
:high_voltage: Links HAZOP → SIS design
:factory: Where it is used
:oil_drum: Oil & Gas
:alembic: Chemical plants
:high_voltage: Power plants
:factory: Process industries
:bullseye: Key concept
:backhand_index_pointing_right: Risk = Frequency × Consequence
:backhand_index_pointing_right: LOPA ensures risk is reduced to acceptable level
:backhand_index_pointing_right::backhand_index_pointing_right: WATCH VIDEOS:
:warning: Important
:cross_mark: Not guesswork
:cross_mark: Not just documentation
:white_check_mark: Data-driven safety decision tool
:backhand_index_pointing_right: HAZOP finds hazards
:backhand_index_pointing_right: LOPA checks if protection is enough
#ProcessSafety #LOPA #FunctionalSafety #SIS #Instrumentation Automation #ControlSystems #Engineering #IndustrialSafety #IEC61511 :rocket:
