Main Parts of a Control Valve
:gear: Control Valve Parts β€” Explained Simply
A control valve is the final control element in any process loop.
But what actually makes it work so precisely? :backhand_index_pointing_down:
:brain: Main Parts of a Control Valve
:small_blue_diamond: Valve Body
:right_arrow: The main casing where fluid flows
:right_arrow: Designed to handle pressure, temperature & flow
:small_blue_diamond: Trim (Heart of the Valve)
:right_arrow: Controls the actual flow inside the valve
Includes:
:small_orange_diamond: Plug
:small_orange_diamond: Seat
:small_orange_diamond: Stem
:backhand_index_pointing_right: This is where flow regulation happens
:small_blue_diamond: Actuator
:right_arrow: Provides the force to move the valve
Types:
:small_orange_diamond: Pneumatic
:small_orange_diamond: Electric
:small_orange_diamond: Hydraulic
:small_blue_diamond: Positioner
:right_arrow: Ensures valve moves to the exact position
:right_arrow: Converts signal (4–20 mA / FF / HART) β†’ Valve movement
:small_blue_diamond: Bonnet
:right_arrow: Connects body and stem
:right_arrow: Protects internal components
:small_blue_diamond: Packing
:right_arrow: Prevents leakage along the stem
:right_arrow: Maintains sealing
:small_blue_diamond: Yoke
:right_arrow: Connects actuator to valve body
:right_arrow: Provides structural support
:small_blue_diamond: Accessories
:right_arrow: Enhance performance
:backhand_index_pointing_right: MORE DETAILS HERE: Basic Parts of Control Valves - Control Valve Functions
Includes:
:small_orange_diamond: I/P Converter
:small_orange_diamond: Limit Switches
:small_orange_diamond: Solenoid Valve
:small_orange_diamond: Air Filter Regulator (AFR)
:bullseye: Simple Understanding
:backhand_index_pointing_right: Signal β†’ Positioner β†’ Actuator β†’ Trim β†’ Flow Control
:light_bulb: Control valve = Brain + Muscle + Precision working together
#Instrumentation #ControlValve #ProcessControl #IndustrialAutomation dcs #Engineering #OilAndGas #ProcessInstrumentation Automation #ControlSystems :rocket:
