Maintenance Override
Imagine an SIS is designed to trip a process when a dangerous condition occurs.
But during maintenance, an instrument is giving a false trip signal.
The technician needs to prevent that signal from initiating an unwanted shutdown while the work is being performed.
:backhand_index_pointing_right: This is where a Maintenance Override may be used.
:small_blue_diamond: What is a Maintenance Override?
A Maintenance Override is a controlled facility that temporarily modifies or overrides the normal response of a safety function to allow maintenance, testing, or troubleshooting.
In an SIS, this should never be treated as a routine operating function.
:warning: When an override is active, the safety protection may be reduced or unavailable.
:factory: Simple SIS Example
Consider:
Pressure Transmitter → Safety PLC → Shutdown Valve
The shutdown occurs when:
Pressure > High-High Setpoint
During maintenance, the transmitter may need to be removed.
A controlled maintenance override can temporarily prevent the maintenance activity from causing an unwanted trip.
:wrench: Maintenance starts
:down_arrow:
:warning: Override applied
:down_arrow:
:hammer_and_wrench: Instrument maintenance
:down_arrow:
:test_tube: Testing completed
:down_arrow:
:white_check_mark: Override removed
:down_arrow:
:locked: Safety function restored
:warning: Maintenance Override vs Normal Operation
A maintenance override should have:
:clipboard: Proper authorization
:busts_in_silhouette: Defined responsibility
:stopwatch: Controlled duration
:police_car_light: Clear indication
:loudspeaker: Operator awareness
:warning: Risk assessment
:memo: Documentation
:counterclockwise_arrows_button: Verification after removal
:police_car_light: What If Someone Forgets It?
This is where the real danger appears.
A maintenance override remains active…
The plant returns to normal operation…
Then a genuine hazardous condition occurs.
:fire: Process condition becomes dangerous
:down_arrow:
:police_car_light: Safety function should operate
:down_arrow:
:cross_mark: Override prevents the intended action
:down_arrow:
:warning: Protection may be lost
:fire: Maintenance Override vs Maintenance Bypass
The exact terminology can vary between SIS vendors and plant procedures, so the project philosophy and cause-and-effect documentation should always be followed.
Generally:
Maintenance Bypass → temporarily prevents a selected safety function/input from producing its normal safety action.
Maintenance Override → broader term that may refer to temporarily overriding the normal logic/action of a safety function for maintenance or testing.
:backhand_index_pointing_right: Always check the SIS design documentation before treating the two terms as technically identical.
:bullseye: Golden Rule
:locked_with_key: A maintenance override is a temporary safety impairment—not a convenience feature.
The objective is simple:
Apply only when necessary → control the risk → perform the work → remove it → verify the SIS is fully restored. :white_check_mark:
#MaintenanceOverride #SIS #SafetyInstrumentedSystem #FunctionalSafety #SIL #IEC61511 #ProcessSafety #SafetyPLC #Instrumentation #IndustrialAutomation dcs #ProcessControl #OilAndGas #SafetyEngineering #InstrumentationEngineer :police_car_light::wrench::factory:
