Management of Change (MOC) in SIS: The Most Dangerous Change is the One Nobody Documents! ![]()
Imagine this…
A technician changes a shutdown valve positioner.
An engineer modifies a Safety PLC logic timer.
A maintenance team replaces a pressure transmitter with a different model.
Nobody updates the documentation.
Nobody reviews the safety impact.
Nobody informs operations.
Then one day…
Process upset occurs.
SIS is expected to protect the plant.
It doesn’t respond as designed.
The investigation begins.
What is MOC in SIS?
Management of Change (MOC) is a formal process used to evaluate, approve, document, test, and communicate any change that could affect the Safety Instrumented System (SIS).
An SIS is designed to save lives, protect assets, and prevent environmental incidents.
Even a small change can significantly impact safety performance.
Changes That Require MOC
Safety PLC logic modifications
SIF setpoint changes
Bypass strategy changes
Instrument replacement with different specifications
Shutdown valve modifications
Cause & Effect updates
Network architecture changes
Cybersecurity updates
Alarm philosophy changes
Firmware and software upgrades
Why MOC is Critical?
Without MOC:
Hidden risks increase
Safety Integrity Level (SIL) assumptions may become invalid
Documentation becomes inaccurate
Proof testing may miss critical failures
Regulatory compliance issues arise
Incident investigations become difficult
A Good SIS MOC Process Includes
Hazard and risk assessment
SIL impact evaluation
Engineering review
Operations approval
Implementation planning
Functional testing
Documentation updates
Personnel training
Final authorization before startup
The Golden Rule
“No change is too small for review when safety is involved.”
A 5-minute logic modification can create a million-dollar incident.
A single undocumented change can defeat years of safety engineering.
In Safety Instrumented Systems, the biggest risk is often not equipment failure… it’s uncontrolled change.
#SIS #SafetyPLC #FunctionalSafety #SIL #IEC61511 #ProcessSafety #Instrumentation Automation #ControlSystems #Engineering #SafetyInstrumentedSystem #ManagementOfChange #MOC #IndustrialSafety #ProcessControl #ShutdownSystem #SafetyEngineering #ChemicalPlant #OilAndGas #IndustrialAutomation ![]()
