Multiple Choice Questions and Answers on Measuring Instruments.
The micrometer principle of measurement is also applied to:
(a) Inside measurement
(b) Depth measurement
© Screw threads measurement
(d) All of the above -
Instrument used for angular measurement.
(a) Protractors
(b) Vernier level protractors
© Dial level protractors
Engineer’s steel rule is a precision measuring instruments and must be treated as such, and kept in a:
(a) Polished condition
(b) Fine condition
© Corrosion condition
(d) None of the above -
The scale can be manufactured in different sizes and scales, the scale is available in:
(a) 150 mm and 30 mm lengths
(b) 600 mm and 1000 mm lengths
© All of the above
Shrinking rules are the scales used in foundry shop and:
(a) Forging shop
(b) Pattern making shop
© Welding shop
The desirable qualities of steel rule are:
(a) Good quality spring steel and clearly engraved Lines
(b) Reputed make and Metric on two edges
© Thickness should be minimum
The joints locate the legs is a straight line during service and also allow the rule to fold into a convenient
length.
(a) Measuring Tip
(b) Folding Rule
© Hook Rule
The degree of accuracy which can be obtained measurements with a steel rule or scale depend:
(a) Quality of the rule
(b) Skill of the user
© Both of the above
(d) None of the all -
Intended for use in tailoring or dress making are typically made of flexible cloth or plastic:
(a) Folding rule
(b) Holding rule
© Measuring Tip
It is a metal plate with an optically flat surface which is as a plane of reference:
(a) Angle plate
(b) Surface plate
© Both of the above
The setting of the surface plate is done with the help of screws jack or:
(a) Nut & Bolts
(b) Nails
© Adjusting Screws
The straightness can be measured by the method of:
(a) Straight edge methods and the wedge method
(b) The level method
© The autocollimator method
It consists a scaled glass tube, which contains ether vapour in the form of a bubble:
(a) Engineering parallels
(b) Spirit levels
© Dial indicator
Engineers parallels are available:
(a) Solid type
(b) Box type
© Adjustable type
Combination set the squaring and scale cube used for:
(a) Height measurement
© Both of above
(d) None of all -
Graduated measuring instruments incorporate graduate spacing representing known:
(a) Circles
(b) Squares
© Distance
(d)None of the above
