Normally, diodes will not conduct when reverse-biased, but if the reverse voltage is increased further, a point will be reached where the diode gives up and allowing the current to surge.
This voltage is one of the limiting parameter of diodes and is known as
A. breakdown voltage (VBR)
B. peak inverse voltage (PIV)
C. peak reverse voltage (PRV)
D. all are correct
