Op-amps have two input terminals namely, the inverting (-) and non-inverting (+) inputs.
What is the significance of its name?
A. If a sine-wave is applied to the inverting (-) input, the output will be inverted or shifted by 180°, while if applied to the non-inverting (+) there will be no phase shift at the output.
B. If pulses are applied to the inverting (-) input, the positive pulse becomes negative at the output and vice versa, while if applied at the non-inverting (+) there will be no reversal of the pulse at the output.
C. In dc amplifier applications, increasing input at the inverting (-) terminal causes the output to decrease and vice versa, while at the non-inverting (+) input, the output magnitude goes with the input.
D. all of these are correct
