Oscillators MCQ Questions and Answers for the EE AND ECE engineering students.
Q 1 . An oscillator converts ………………
c. power into d.c. power
c. power into a.c. power
mechanical power into a.c. power
none of the above
Answer : 2
Q 2 . In an LC transistor oscillator, the active device is ……………
LC tank circuit
Biasing circuit
Transistor
None of the above
Answer : 3
Q 3 . In an LC circuit, when the capacitor is maximum, the inductor energy is ……….
Minimum
Maximum
Half-way between maximum and minimum
None of the above
Answer : 1
Q 4 . In an LC oscillator, the frequency of oscillator is ……………. L or C.
Proportional to square of
Directly proportional to
Independent of the values of
Inversely proportional to square root of
Answer : 4
Q 5 . An oscillator produces……………. oscillations
Damped
Undamped
Modulated
None of the above
Answer : 2
Q 6 . An oscillator employs ……………… feedback
Positive
Negative
Neither positive nor negative
Data insufficient
Answer : 1
Q 7 . An LC oscillator cannot be used to produce ………………… frequencies
High
Audio
Very low
Very high
Answer : 3
Q 8 . Hartley oscillator is commonly used in ………………
Radio receivers
Radio transmitters
TV receivers
None of the above
Answer : 1
Q 9 . In a phase shift oscillator, we use …………. RC sections
Two
Three
Four
None of the above
Answer : 2
Q 1 0 . In a phase shift oscillator, the frequency determining elements are …………
L and C
R, L and C
R and C
None of the above
Answer : 3
Q 1 1 . A Wien bridge oscillator uses ……………. feedback
Only positive
Only negative
Both positive and negative
None of the above
Answer : 3
Q 1 2 . The piezoelectric effect in a crystal is ……………
A voltage developed because of mechanical stress
A change in resistance because of temperature
A change in frequency because of temperature
None of the above
Answer : 1
Q 1 3 . If the crystal frequency changes with temperature, we say that crystal has …………… temperature coefficient
Positive
Zero
Negative
None of the above
Answer : 1
Q 1 4 . The crystal oscillator frequency is very stable due to ………………. of the crystal
Rigidity
Vibrations
Low Q
High Q
Answer : 4
Q 1 5 . The application where one would most likely find a crystal oscillator is ………………
Radio receiver
Radio transmitter
AF sweep generator
None of the above
Answer : 2
Q 1 6 . An oscillator differs from an amplifier because it ………
Has more gain
Requires no input signal
Requires no d.c. supply
Always has the same input
Answer : 2
Q 1 7 . One condition for oscillation is ………….
A phase shift around the feedback loop of 180o
A gain around the feedback loop of one-third
A phase shift around the feedback loop of 0o
A gain around the feedback loop of less than 1
Answer : 3
Q 1 8 . A second condition for oscillations is ……………….
A gain of 1 around the feedback loop
No gain around the feedback loop
The attention of the feedback circuit must be one-third
The feedback circuit must be capacitive
Answer : 1
Q 1 9 . In a certain oscillator A v = 50. The attention of the feedback circuit must be …………
| 1. | 1 |
| 2. | 01 |
| 3. | 10 |
| 4. | 02 |
Answer : 4
Q 2 0 . For an oscillator to properly start, the gain around the feedback loop must initially be
1
Greater than 1
Less than 1
Equal to attenuation of feedback circuit
Answer : 2
Q 2 1 . In a Wien-bridge oscillator, if the resistances in the positive feedback circuit are decreased, the frequency……….
Remains the same
Decreases
Increases
Insufficient data
Answer : 3
Q 2 2 . In Colpitt’s oscillator, feedback is obtained …………….
By magnetic induction
By a tickler coil
From the centre of split capacitors
None of the above
Answer : 3
Q 2 3 . The Q of the crystal is of the order of …………
100
1000
50
More than 10,000
Answer : 4
Q 2 4 . Quartz crystal is most commonly used in crystal oscillators because ………….
It has superior electrical properties
It is easily available
It is quite inexpensive
None of the above
Answer : 1
Q 2 5 . This question will be available soon
Q 2 6 . This question will be available soon
Q 2 7 . …………… is a fixed frequency oscillator
Phase-shift oscillator
Hartely-oscillator
Crystal oscillator
Answer : 4
Q 2 8 . In an LC oscillator, if the value of L is increased four times, the frequency of oscillations is …………
Increased 2 times
Decreased 4 times
Increased 4 times
Decreased 2 times
Answer : 4
Q 2 9 . An important limitation of a crystal oscillator is ……………
Its low output
Its high Q
Less availability of quartz crystal
Its high output
Answer : 1
Q 3 0 . The signal generator generally used in the laboratories is …………… oscillator
Wien-bridge
Hartely
Crystal
Phase shift
Answer : 1
