Power lost as wattage along the length of the circuit conductors is dissipated as heat.
The excessive voltage drop will cause excessive heat buildup. In addition to not being corrected (by increasing the conductor wire size to lower the conductor resistance), it affects the connected utilization equipment performance, the heat buildup can lead to conductor insulation failure, which will cause even more critical circuit problems.
A) True
B) False
Answer:A
