Proportional band of a controller is defined as the ___
Proportional band of a controller is defined as the range of:
A. Measured variable to the set variable
B. Air output as the measured variable varies from maximum to minimum
C. Measured variables through which the air output varies from maximum to minimum
D. None of the above
