Radar vs Ultrasonic Level Sensor: Which Is Better for Your Application?
Radar and ultrasonic level sensors are both non-contact technologies used to measure liquid and solid levels. While they may appear similar, they work on different principles and perform differently in real-world conditions. Radar sensors use electromagnetic waves and offer excellent performance in dust, steam, foam, and harsh industrial environments. Ultrasonic sensors use sound waves and are a cost-effective solution for clean liquids and simple applications. Choosing the right sensor depends on your measuring medium, installation environment, accuracy requirements, and budget.
What Is a Radar Level Sensor?
A radar level transmitter is a non-contact measuring device that determines the distance between the sensor and the material surface using microwave signals. The sensor transmits high-frequency radar waves, which reflect from the target surface and return to the antenna. The device then calculates the level based on the travel time or frequency difference of the reflected signal.
Because radar waves are largely unaffected by temperature, pressure, dust, vapor, or humidity, radar level sensors are widely used in demanding industrial environments such as chemical tanks, oil storage, grain silos, wastewater plants, and bulk material storage.
Modern 80 GHz radar technology provides a narrow beam angle, allowing accurate measurement even in small tanks or installations with internal obstacles.
What Is an Ultrasonic Level Sensor?
An ultrasonic level transmitter also measures level without contacting the medium, but it works by emitting high-frequency sound waves. The sound pulse travels through the air, reflects from the material surface, and returns to the sensor. The sensor calculates the distance based on the echo time.
Ultrasonic technology is commonly used for water tanks, reservoirs, irrigation systems, pump stations, and open-channel monitoring. They are easy to install, require little maintenance, and offer a cost-effective solution for clean liquid applications.
However, because sound waves travel through air, their performance can be affected by environmental factors such as temperature changes, wind, steam, condensation, and heavy dust.
Radar vs Ultrasonic: Key Differences
Although both technologies are designed for non-contact level measurement, they differ significantly in performance.
Feature Radar Ultrasonic
Measuring Principle Microwave radar waves Ultrasonic sound waves
Contact with Medium Non-contact Non-contact
Accuracy Very high Moderate
Dust Resistance Excellent Limited
Steam & Vapor Excellent Affected
Foam Performance Good Moderate
Measuring Range Larger (Like 120 m) Moderate (like 60m)
Maintenance Very low Low
Cost Higher Lower
For simple applications, both technologies can provide reliable results. However, the performance gap becomes much more noticeable in challenging industrial environments.
Which Sensor Performs Better in Different Applications?
Choosing the right sensor depends more on the application than on the technology itself.
Clean Water Tanks
For municipal water tanks, reservoirs, and irrigation systems with clean liquids, ultrasonic sensors are often an economical choice. They provide sufficient accuracy while keeping equipment costs low.
Grain, Cement, and Powder Silos
Dust can interfere with ultrasonic signals, causing unstable readings. Grain silo radar level sensors perform much better because microwave signals can penetrate dusty environments and maintain stable measurements.
Chemical and Oil Storage Tanks
Chemical tanks often contain vapors, pressure changes, or condensation that affect ultrasonic performance. Radar sensors are generally the preferred solution because they are largely immune to these conditions.
Wastewater and Pump Stations
If foam, turbulence, or floating debris is present, radar sensors typically provide more reliable measurements. For relatively clean wastewater, ultrasonic sensors may still be a practical and cost-effective option.
Outdoor Rivers and Reservoirs
Rain, fog, humidity, and changing weather conditions can influence ultrasonic measurements. Radar sensors offer greater stability for long-term outdoor monitoring and remote water level applications.
How to Choose Between Radar and Ultrasonic Sensors
Before selecting a level sensor, consider the following questions:
What material are you measuring? Liquids, powders, grains, and chemicals require different solutions.
How challenging is the environment? Dust, steam, foam, and condensation usually favor radar technology.
What measuring range is required? Long-distance measurement is generally better suited for radar.
How much accuracy do you need? High-precision process control often requires radar sensors.
What is your budget? Ultrasonic sensors typically have a lower initial investment for straightforward applications.
In many industrial projects, selecting the lowest-cost sensor may not always deliver the lowest overall operating cost. Choosing the right technology from the beginning can reduce maintenance, avoid measurement errors, and improve process reliability.
Which One Should You Choose?
There is no single “best” level sensor for every application. If your application involves clean liquids, short measuring distances, and a controlled environment, an ultrasonic level sensor is often an excellent balance between performance and cost.
If your process includes dust, steam, foam, long measuring distances, harsh weather, or demanding industrial conditions, a radar level sensor is usually the more reliable long-term solution. Its superior environmental adaptability and measurement stability make it the preferred choice for many industrial automation projects.
Ultimately, understanding your application requirements is the key to selecting the right technology.
Learn More About Radar Technology
If you’re considering radar technology for challenging level measurement applications, you can choose an 80GHz radar. Refer to our previous article about this details.
In that article, we explore:
How 80 GHz FMCW radar technology works
Why it performs exceptionally well in grain silos
The differences between 26 GHz, 60 GHz, and 80 GHz radar
Real-world grain storage applications
Practical tips for selecting the right radar level sensor
Whether you’re measuring grain, powders, liquids, or bulk solids, understanding the capabilities of modern 80 GHz radar technology can help you achieve more accurate and reliable level monitoring while reducing maintenance costs and improving operational efficiency.
Frequently Asked Questions (FAQs)
  1. Can radar level sensors work in foam?
    Yes. Radar level sensors can usually measure through moderate foam because microwave signals are less affected by foam compared with ultrasonic sound waves. However, extremely thick or conductive foam may require proper antenna selection and parameter adjustment.
  2. Is radar level sensor better than ultrasonic for dusty environments?
    Yes. Radar level sensors generally perform better in dusty environments because microwave signals are not significantly affected by dust particles in the air.
  3. Can ultrasonic level sensors replace radar level sensors?
    In some applications, yes.
  4. Why is radar level sensor more accurate than ultrasonic sensor?
    Radar level sensors use high-frequency FMCW radar technology, which provides a narrower beam angle, higher measurement resolution, and better signal processing capability. This allows accurate measurement in small tanks, complex installations, and challenging industrial environments where ultrasonic sensors may struggle.
  5. Are radar level sensors more expensive than ultrasonic sensors?
    Radar level sensors usually have a higher initial cost compared with ultrasonic sensors because they use more advanced technology and signal processing.
  6. Can radar level sensors measure both liquids and solids?
    Yes. Radar level sensors can measure a wide range of materials, including liquids, powders, grains, and bulk solids. They are commonly used in applications such as chemical tanks, oil storage tanks, grain silos, cement silos, and mining material storage.
