Safety lifecycle as per IEC 61511
:shield: Safety Lifecycle as per IEC 61511 — Explained Simply
Functional safety is not just design…
It’s a complete lifecycle from concept to operation :backhand_index_pointing_down:
:gear: What is Safety Lifecycle?
:right_arrow: A structured approach defined in IEC 61511
:right_arrow: Covers design, implementation, operation, and maintenance
:right_arrow: Ensures safety is maintained throughout the plant life
:brain: Why it matters
:backhand_index_pointing_right: Safety is not one-time… it must be managed continuously
:counterclockwise_arrows_button: Main Stages of Safety Lifecycle
:green_circle: 1. Hazard & Risk Analysis
:right_arrow: Identify hazards using HAZOP / risk studies
:right_arrow: Define required risk reduction
:yellow_circle: 2. LOPA & SIL Determination
:right_arrow: Evaluate protection layers
:right_arrow: Assign required SIL level
:blue_circle: 3. Safety Requirements Specification (SRS)
:right_arrow: Define what the safety system must do
:right_arrow: Includes logic, response time, trip conditions
:purple_circle: 4. Design & Engineering
:right_arrow: Design SIS architecture
:right_arrow: Select sensors, logic solver, final elements
:orange_circle: 5. Installation & Commissioning
:right_arrow: Install hardware
:right_arrow: Perform loop checks & integration
:red_circle: 6. Validation
:right_arrow: Test if system works as per SRS
:right_arrow: Confirm safety functions (SIFs)
:brown_circle: 7. Operation & Maintenance
:right_arrow: Routine testing
:right_arrow: Proof testing of safety loops
:right_arrow: Fault handling
:black_circle: 8. Modification & Decommissioning
:right_arrow: Manage changes safely
:right_arrow: Proper shutdown at end of lifecycle
:backhand_index_pointing_right::backhand_index_pointing_right: WATCH VIDEO:
:bullseye: Key idea
:backhand_index_pointing_right: Safety is not just design… it’s a continuous process
:warning: Important
:cross_mark: Skipping steps = Unsafe system
:white_check_mark: Following lifecycle = Reliable safety
:backhand_index_pointing_right: Design → Test → Operate → Maintain → Improve
#FunctionalSafety #IEC61511 #SIS #ProcessSafety #Instrumentation Automation #ControlSystems #Engineering #IndustrialSafety #SafetyEngineering :rocket:
