The Solar-Powered AWLR System (Automatic Water Level Recorder) is designed for auto water level monitoring, suitable for remote, off-grid, or hard-to-access locations. By combining high-accuracy water level sensors with solar panels and battery energy storage, the system enables continuous and reliable monitoring without relying on external power sources.
This solution is widely used in river monitoring, reservoirs, flood warning systems, groundwater observation, and environmental monitoring, especially in areas where grid power is unavailable or unstable.
A typical solar-powered AWLR system consists of a water level sensor, low-power data logger, solar panel, rechargeable battery, wireless communication module, and a remote monitoring platform. The system automatically collects real-time water level data and transmits it to a cloud or control center for analysis and decision-making.
Key Components of a Solar-Powered AWLR System
1. Water Level Sensor Selection
The sensor should be chosen based on the application environment. For example, submersible level sensors are more suitable for rivers, wells, and groundwater, radar level sensors for open channels and harsh environments, and ultrasonic level sensors for non-contact measurement in clean water.
We should also consider from the aspects of measurement range, accuracy, temperature tolerance, and corrosion resistance.
2. Solar Power Panel Unit
A properly sized solar panel and battery is critical. Typical solar systems consist of a 12 V or 24 V battery combined with a solar charge controller. Sensors must operate reliably within this voltage range.
If multiple devices are powered by the system, use a higher-capacity battery based on the total power consumption, or set the system as a power-saving mode to reduce energy consumption and extend battery life. Besides, we should also consider the local sunlight conditions, install the panel at a proper angel.
3. Low-Power Data Logger and Communication
Wireless communication options such as 4G, LoRa, or LoRaWAN enable remote data transmission. 4G is suitable for real-time data and frequent uploads; LoRa/LoRaWAN is ideal for low-power, long-distance applications.
4. Remote Monitoring Platform
The system supports standard signals and protocols such as 4–20 mA, RS485, and Modbus, ensuring easy integration with existing SCADA systems or cloud platforms for real-time monitoring and historical data analysis.
5. Environmental Protection and Reliability
Outdoor installations require robust enclosures with high IP protection levels, along with resistance to moisture, lightning, and electromagnetic interference.
Key Advantages of Solar-Powered AWLR Systems
1. Independent Power Supply for Remote Sites
Solar panels combined with high-capacity batteries provide long-term, stable power, making the system ideal for remote rivers, reservoirs, mountains, and rural areas without grid access.
2. Low Power Consumption and Long-Term Operation
Optimized low-power design allows the system to operate for a long time with minimal maintenance. Users can configure working cycles (e.g., measuring every 5 minutes and sleeping for 1 hour) to further reduce energy consumption.
3. Continuous and Reliable Water Level Monitoring
The system delivers 24/7 automatic water level measurement, ensuring accurate and consistent data even under harsh environmental conditions.
4. Reduced Installation and Maintenance Costs
Without the need for power cabling, installation becomes faster and more cost-effective. Reduced on-site visits also lower long-term operation and maintenance costs.
5. Wireless Monitoring Capability
The system supports remote monitoring via PC or APP with the combination of wireless gateways. Users can access real-time data and historical records anytime, anywhere on the Cloud Platform. Alerts and notifications are automatically sent when anomalies are detected. The cloud platform also enables seamless integration with third-party systems for expanded functionality.
Typical Applications of Solar-Powered AWLR Systems
River and canal water level monitoring
Reservoir and dam safety monitoring
Flood early warning systems
Urban drainage and stormwater monitoring
Groundwater and well water level observation
Remote water resources and environmental monitoring stations
