A capacitor __________
A) is manufactured as a wound or spiral-wrapped coil of continuous wire which is normally mounted on an iron core
B) is referred to as a voltage device because it stores electrical energy in an electrostatic field across the dielectric between at least two conductive plates or other conductive surfaces.
C) Both consists of two or more conductive plates with an insulating, non-conducting plate — dielectric — between them & is referred to as a voltage device because it stores electrical energy in an electrostatic field across the dielectric between at least two conductive plates or other conductive surfaces.
D) consists of two or more conductive plates with an insulating, non-conducting plate — dielectric — between them
Answer:C
