The flow rate of water passing through a venturi can be determined by measuring the…
A. differential pressure of the water as it passes through the venturi.
B. change in the velocity of the water as it passes through the venturi.
C. linear displacement of a metering plug installed in the throat of the venturi.
D. rotation rate of a paddle wheel-type device installed in the throat of the venturi.
Answer:A
