The _______________________ motor -starter is normally supplied (purchased) with a minimum of one set of NO auxiliary contacts (control contacts) that are activated with the power contacts ___
The _______________________ motor -starter is normally supplied (purchased) with a minimum of one set of NO auxiliary contacts (control contacts) that are activated with the power contacts.
These contacts can be used as a switch to control indicating lights, other motor -starters, or as the necessary seal-in contacts in a 3-wire control circuit.
A) electromagnetic
B) full-voltage
C) Any of the answers
D) across-the-line
Answer:C
