The oil-pressure failure switches of a mechanical refrigeration system
a. keep the compressor oil pressure at a level where the oil will not freeze
b. prevent compressor start-up if the oil heater fails
c. separate refrigerant dissolved in the oil from the lubricant
d. shut down the compressor when the oil pressure drops below the minimum required value
e. keep the oil from freezing at low pressure
Answer: d
