The temperature control valve is currently 50 percent open. If the cooling water inlet temperature decreases, the temperature controller will position the temperature control valve more ___, causing cooling water differential ___
lube oil temperature control system-PG-25
If the cooling water inlet temperature decreases, the temperature controller will position the temperature control valve more __________, causing cooling water differential temperature through the heat exchanger to __________.
A. closed; increase
B. closed; decrease
C. open; increase
D. open; decrease
