The temperature controller is a direct-acting proportional controller with a gain of 1.0. Which one of the following describes the effect of changing the gain to 2.0 ___
lube oil temperature control system-PG-25
Which one of the following describes the effect of changing the gain to 2.0?
A. Half the temperature deviation from setpoint will produce a given controller output.
B. Twice the temperature deviation from setpoint will produce a given controller output.
C. The temperature control valve will move half as far for a given change in controller output.
D. The temperature control valve will move twice as far for a given change in controller output.
