The two motors are controlled with a 3-position selector switch, the control or run status of the two motors are interlocked with the single switch.
If both motors are to be OFF in the center position of the switch, then both sets of contacts should be at-rest in their ___________ configuration.
____________ is commanded to start when the switch is turned to the left position.
___________ is commanded to start when the switch is turned to the right position.
A) NC; Motor 2; Motor 1
B) NC; Motor 1; Motor 2
C) NO; Motor 2; Motor 1
D) NO; Motor 1; Motor 2
Answer:D
