Too often just any available fuse is used to replace a blown fuse. This haphazard approach can result in damaged equipment and in some instances it can be a safety hazard (due to the resulting fire or explosion of the electrical equipment) ___
This haphazard approach can result in damaged equipment and in some instances it can be a safety hazard (due to the resulting fire or explosion of the electrical equipment).
Unless changes within the machinery or process equipment have been made, an open fuse should not be replaced, even with a fuse that has the same type, voltage, and current ratings.
A) True
B) False
Answer:A
